How to avoid condensation problems in my drive installation
  • Industrial Automation
  • Solutions for Motor Management
  • How to avoid condensation problems in my drive installation
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
14
Bastian_Schmitz
11
Back to Solutions for Motor Management
AlexandreBoulet
Administrator AlexandreBoulet Administrator
Posted: ‎2021-03-26 12:07 AM . Last Modified: ‎2021-03-26 12:56 AM
3
2713
Hello, I need to design a drive installation for a sugar mill located in a tropical environment similar to the one pictured. There the  customer is facing quite high humidity levels and temperature differences between day / night. Has someone experience with VSD´s in such environments? Thanks
Alexandre Boulet
Schneider Electric - Exchange Launch Leader
  • Design & Build
BJacqz
Commander
Posted: ‎2021-03-26 03:08 AM
The change of temperature in a cabinet can create some condensation on the components of the cabinet.
It appears generally just after power on a cabinet, all components / products are cold and get higher in temperature, this difference can create condensation...
Different solutions will help to reduce or solve this kind of phenomena.
It is possible to let the concerned product always connected on the main, this allows to keep inside product a stable temperature and then avoid possible condensation. This will avoid possible condensation inside the product only.
Another possibility to help reducing condensation is to install a small heater inside the cabinet (preferable possible with a thermal setting), then it will allow a stable temperature in all cabinet and then avoiding this phenomena for all components of the cabinet...
the thermal setting will allow an adjustment of temperature and then avoid energy consumption when it is not necessary.
Bruno Jacqz, Drives training leader
BJacqz
Commander
ReinhardK
Ensign ReinhardK Ensign
Ensign
Posted: ‎2021-04-01 08:10 AM
Condensation appears when air is cooled down lower than its dew point, which depends on the relative humidity and air pressure.
Look for a h-x diagram or calculator on the web to figure out this critical temperature.
On electrical installations, it´s critical when the cubical inside temperature is lower than on outside temperature, or the cooling air temperature.
To avoid problems hold the inner temperature higher than on the outside, this can be done by installing space heaters.
When AC units are used, make sure to set the cooling temperature not lower than the dew point.
Special cautions are necessary on liquid-cooled drive installations, follow here the guides in the corresponding ATV manuals.
  • condensation
  • liquid cooled
  • space heater
  • water cooled
MitchS
Crewman MitchS Crewman
Crewman
Posted: ‎2021-04-14 08:35 AM
To add to the other comments:
For new enclosed drives being quoted, some options are available such as VW3AP0501 enclosure heating and VW3AP2101 for motor heating (motors can get condensation in them as well as the cabinets).
For existing installations, SE has the ClimaSys™ Thermal Management System to help with heating, cooling, and monitoring enclosures of all types along with the software to monitor and inform decisions on everything.
01001000 01101001 00100001
There are 10 types of people in the world. Those who understand BINARY, and those who don't.
