How VFD provide short circuit protection to the motor?
  • Industrial Automation
  • Solutions for Motor Management
  • How VFD provide short circuit protection to the motor?
BJacqz
Commander BJacqz Commander
48
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
13
Bastian_Schmitz
11
Back to Solutions for Motor Management
Posted: ‎2022-10-16 11:53 PM
1
1503
BJacqz
Commander
Posted: ‎2022-10-21 09:11 AM
According to MLI voltage sent to motor, the drive can check permanently the current on motor side. When a short circuit on motor occurs, rapidly (less than some millisecond) the motor current increased to high value and is immediately stopped by transistor managed inside the inverter. This protection is done according to transistor characteristics. Thank you to tell this is enough explanation.
Bruno Jacqz, Drives training leader
BJacqz
Commander
