Can a GV2ME motor circuit breaker be used on the infeed of a servo drive?
  • Industrial Automation
  • Solutions for Motor Management
  • Can a GV2ME motor circuit breaker be used on the infeed of a servo drive?
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
TeSys Deca - frame 2
Back to Solutions for Motor Management
touge
touge
Cadet
Posted: ‎2023-10-27 12:08 AM
Hi ,
I have a question about the Tesys GV2ME series motor circuit breaker
I am importing some machine from China to US,
The main breaker for this panel is NSC160S series.
And the panel has 10 servo drives inside.
However, the vendor was using an UL1077 MCB(OMSC65H) for each servo drives' power infeed,
In my understanding it is not meet the NFPA 79 standard.
I understand the easier way is to change the UL1077 MCB to UL489 MCB such as C60BP series.
However, C60BP is not easy to get in China.
So, I am looking for an alternative solution,
In my past experience, some drives manufacture recommend either UL489 MCB or a MPCB for drive protection.
Therefore, I am looking for GV2ME to replace UL1077 MCB for each power infeed of servo drive.
Is that okay for this application for US standard(NFPA,NEC...) ?
Replies 0
