Altivar atv71 forward direction
  • Industrial Automation
  • Solutions for Motor Management
  • Altivar atv71 forward direction
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Posted: ‎2022-07-29 01:21 AM
2
1871
The input pin for forward direction LI1 isn't working
Is it possible to program LI5 for forward direction instead of LI1
BJacqz
Commander
Posted: ‎2022-10-14 06:12 AM
On ATV71, LI1 is always set to forward.
Other functions can be set to this LI1 acccording to the feature available "multi assignment".
May be you can check first that the LI1 is really activated. Have a look inside the I/O Map. As shown on linked picture
Check that the drive is on "rdy" before you switch on LI1, check that PWR is activated (power removal), this is a safety input avoiding motor to start in case this is not activated. For information, on new drive now, it is named Safe Torque Off (STO)
Bruno Jacqz, Drives training leader
Kevin_McDonald
Ensign Kevin_McDonald Ensign
Ensign
Posted: ‎2022-12-05 05:23 AM
LI1 is forward or run permissive.
Check in the IO Map if LI1 is high or low.  If low and does not respond, confirm for 24VDC between 24V and COM.  If there is still no response, recommend to replace the control board.
If LI1 is stuck in high, you may be able to change to 3 wire control where LI1 is permissive and LI2 is run forward.
BJacqz
Commander
Kevin_McDonald
Ensign
