Altivar Process ATV6000 11kV Vs 6.3kV Cost Simulator
  • Industrial Automation
  • Solutions for Motor Management
  • Altivar Process ATV6000 11kV Vs 6.3kV Cost Simulator
BJacqz
Commander BJacqz Commander
48
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
13
Bastian_Schmitz
11
Altivar Process (Medium Voltage)
Back to Solutions for Motor Management
sesa217163_brid
Lieutenant JG sesa217163_brid Lieutenant JG
Lieutenant JG
Posted: ‎2021-11-11 03:11 AM . Last Modified: ‎2022-12-02 04:09 AM
1
1970
Hello Team
I need to work out a global value study to check for overall ED cost for 6.3kV with reference to 11kV.
Do we have any tools which can help to compare the prices of MV Drives for these ranges?
Application: Mills, Klin (for cement facility)
Best Regards
Shailesh Chetty
PriscilaCunha22
Lieutenant JG
Posted: ‎2022-01-12 01:10 PM . Last Modified: ‎2022-01-17 10:12 AM
Hi Shailesh!
We don't have tool to compare the prices to send you. The MV Drive ATV6000 we quote by project.
But for your case study you can contact directly the local Drives Team, then they can help to provide an estimated price for the ranges you need.
Best regards,
PriscilaCunha22
Lieutenant JG
Hi Shailesh!
Best regards,
