ATV6000 Protection Functions
  • Industrial Automation
  • Solutions for Motor Management
  • ATV6000 Protection Functions
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
vermas
Crewman vermas Crewman
Crewman
Posted: ‎2023-11-16 01:52 AM
2
1601
Dear Team,
Below are the protection function available in output of ATV6000:
  • Ground fault protection at motor side(SCF1,PWF3)
  • Ground short circuit(SCF3)
  • Load short-circuit error(SCF5)
  • Negative sequence current protection : VFD has protection in case of input phase loss and input phase rotation(by KX)
  • Undervoltage protection(USF)
  • Overvoltage protection(OSF)
  • Output phase loss(OPL)
  • Input phase loss(IPL)
  • Restart inhibit protection(TCT):Automatic restart inhibit can be set in the configuration so the drive should not automatically restart after a failure.
  • Apparatus thermal protection<=>Transformer and cabinet over temperature protection
  • DriveTemp ErrorResp(OHL)
  • Motor Excessive start Time protection(STPC)
  • Motor Overspeed protection(SOF)
  • LR looked rotor thermal overload<=>Overcurrent protection(OCF)
  • Motor Winding over temperature protection
Where I can find the default factory settings for above protection functions?
Sudhanshu Verma
  • Medium Voltage AC Drives
PriscilaCunha22
Lieutenant JG
Posted: ‎2023-11-17 01:51 AM
Hello @vermas
Please refer to the Programming Manual.
We also have expert and service manuals dedicated to the Service team, and they can support with additional information.
https://www.se.com/us/en/download/document/QGH83265/
PriscilaCunha22
Lieutenant JG
Hello @vermas
BrownSugar
Lieutenant JG BrownSugar Lieutenant JG
Lieutenant JG
Posted: ‎2023-11-17 05:51 AM
Thank you for the question
