ATV6000 Communication Protocol Availability
  • Industrial Automation
  • Solutions for Motor Management
  • ATV6000 Communication Protocol Availability
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Bastian_Schmitz
11
Back to Solutions for Motor Management
Posted: ‎2021-11-11 10:00 AM
1
1192
Whether Canbus & Modbus Serial RS485 communication protocol is available in the ATV6000 series MV MVD
  • Products
Posted: ‎2021-11-15 10:43 PM
Altivar Process drives have 3 built-in RJ45 communication ports as standard:
• 1 EtherNet/IP and Modbus TCP dual port
• 1 serial port
and has option to includes such module below:
for more information please check:
ATV6000 handbook
https://www.se.com/ww/en/download/document/QGH83255/
• 1 serial port
ATV6000 handbook
