ATV 6000
  • Industrial Automation
  • Solutions for Motor Management
  • ATV 6000
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Altivar Process (Medium Voltage)
Back to Solutions for Motor Management
Posted: ‎2021-11-20 05:33 AM . Last Modified: ‎2022-12-02 04:10 AM
1
2181
ATV 6000
Hi Is there a possibility to Integrate all the ATV 6000 Preventive & Corrective maintenance data in Schneider's Maintenance advisor software, Ecostrxure Maintainance advisor?
If yes any specif part number for ordering?
sesa253016_brid
sesa253016_brid Schneider Alumni (Retired)
Posted: ‎2022-02-16 04:53 AM
Hello Urvish,
It can be possible but needs more investigation on the request and topic. This process should be also analyzed and aligned with the services organization. Can you give more information about the need and request?
Today we manage Preventive and corrective maintenance with the Onsight platform which is linked to bFS (services version of the bFO) which is mainly an internal tool for FSRs and partners with a created report.
