Value change to zero when 3rd party Apps write value to SBO via smartconnector
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Value change to zero when 3rd party Apps write value to SBO via smartconnector
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
YangboLIU
Captain YangboLIU Captain
Captain
Posted: ‎2019-03-19 06:17 PM . Last Modified: ‎2019-03-19 07:01 PM
1590
Hi Expert
Our customer developed an APP to connect SBO via SmartConnector, they can read value from SBO correctly, but whatever the value they write, the value in SBO will change to “0”.
We do a test in office, use SwageUI can write the value correctly, use Postman get the same problem as their APP, we got a capture of  communication when write value to SBO and compare the capture files but did not found any difference except the value of Jason.
Kindly find the attached capture files,source code for change value, and comment us what cause this issue and how to make write operation works correctly.
Thanks and Best Regards
Yangbo
swageUICapture.pcapng
postmancapture.pcapng
Replies 4
JeffBowman
Sisko
Posted: ‎2019-03-20 05:54 AM
1583
Hi Yangbo,
In your Postman packet capture, I am seeing no requests to the EWS Restful gateway at all.
I see a bunch of POSTS to /json (which looks to be a different web service or like maybe you have a WebStation opened).
However, from the pdfs you attached it looks as though they are setting the value of the PUT parameter to
"NewValue" = 34
While the swagger exaple shows the PUT parameter to be:
34
Can you try in POSTMAN to set the PUT parameter to simply the value, and not "NewValue" = value
Best Regards,
-Jeff
YangboLIU
Captain
Posted: ‎2019-03-21 01:51 AM
1578
YangboLIU
Captain
Posted: ‎2019-03-21 01:58 AM
1578
Hi Jeff
Thanks for comments.
The developer modify the source code as your comments but the issue still existing.
Kindly take a look at the screen shot of the capture comparison, the content type may be not correct, Do you agree?
Yangbo
JeffBowman
Sisko
Posted: ‎2019-03-21 04:42 AM
Hi Yangbo,
In the 'Content' on their PUT request, they just need to send the value with no parameter name, they shouldn't form-encode it (it might work in theory, but it clearly is not). Also correct, they should use application/json.
-Jeff
