Soap/Rest endpoint Server showing up under child containers
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Soap/Rest endpoint Server showing up under child containers
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Posted: ‎2017-12-19 07:02 AM
1695
I'm noticing an unusual behavior with the soap/rest endpoint webservice for"/Containers/{id}/Children"​:
It seems like the Root Server Item is being listed as a child for folders.  I haven't been able to identify a well defined pattern, but it only happens for certain folders, and making changes to the folder contents can result in it no longer being listed.
Here is what my test ES looks like:
A request for GET /Containers/00%2FOrangeJuice%2Ftestpoints/Children results in:
[  {     "Name": "OrangeJuice",     "Description": "",     "Type": 1,     "ParentId": "00/OrangeJuice/testpoints",     "Id": "00/OrangeJuice"   },  {     "Name": "AV1",     "Description": "",     "Type": 3,     "Writeable": 1,     "Forceable": 1,     "State": 0,     "Unit": "none",     "Value": "3.14",     "ParentId": "00/OrangeJuice/testpoints",     "Id": "01/OrangeJuice/testpoints/AV1"   },   {     "Name": "Text1",     "Description": "",     "Type": 2,     "Writeable": 1,     "Forceable": 1,     "State": 0,     "Unit": "none",     "Value": "hello",     "ParentId": "00/OrangeJuice/testpoints",     "Id": "01/OrangeJuice/testpoints/Text1"   },   {     "Name": "MSV1",     "Description": "",     "Type": 4,     "Writeable": 1,     "Forceable": 1,     "State": 0,     "Unit": "none",     "Value": "3",     "ParentId": "00/OrangeJuice/testpoints",     "Id": "01/OrangeJuice/testpoints/MSV1"   } ]
If I add a new folder under my testpoints folder, it does not show the root 'OrangeJuice' item in the list anymore and instead shows the new folder I had created.
Tags (9)
  • children
  • container
  • endpoint
  • folder
  • rest
  • root
  • smartconnector
  • soap
  • webservice
Replies 10
sesa180908_brid
Commander
Posted: ‎2017-12-19 07:15 AM
1626
Can you provide the Log file with EwsClient filter enabled and LogLevel of Debug?
Also.  Is it an AS or ES?  Version?
Posted: ‎2017-12-19 07:56 AM
1626
there is no Ews Client filter on the list.  There is 'Csp Client', 'Ews Serve', 'Ews Consume', 'Rest Serve'.
Its an ES, configured as shown above.
Posted: ‎2017-12-19 07:57 AM
1626
sesa180908_brid
Commander
Posted: ‎2017-12-19 08:05 AM
1626
Sorry.  Ews Consume is the one.
Posted: ‎2017-12-19 08:19 AM
1626
okay, i've attached the logs
2017-12-19.capture.log.zip
sesa180908_brid
Commander
Posted: ‎2017-12-19 10:22 AM
1626
Josh,
Can re-run your test again with only "EWS Consume" and "REST Serve" logging filters enabled?
Posted: ‎2017-12-19 10:53 AM
1626
Here it is.  I set the filters, logged into the swagger ui, and rand the /Container/id/Children request at around 1:50pm est
2017-12-19.capture2.log.zip
sesa180908_brid
Commander
Posted: ‎2017-12-19 12:01 PM
1626
Josh.  Its a bug.  It will only manifest itself if there are no children of type Container at the level you are requesting.  I've entered it into the system and I'll try to get a fix out this week.
Posted: ‎2017-12-19 01:09 PM
1626
Okay thanks! looking forward to it
sesa180908_brid
Commander
Posted: ‎2017-12-22 10:09 AM
v2.3.107 includes a fix for this issue.  New version is available from the SmartConnectorServer Download Center.
