Soap/Rest EndPoint is there a way to calculate ID directly from Path?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Soap/Rest EndPoint is there a way to calculate ID directly from Path?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Posted: ‎2017-12-19 01:52 PM
1290
I'm writing a client that will use a list of struxureware paths to consume values from an ES.
It seems like there's a general pattern "##/Path/To/Item" (e.g. "00/Server 1/Folder/MyValue") but since I'm not sure if this pattern holds.
I've been writing my code so that it will explore the containers and create a mapping from path to ID,
but I think in many cases this will consume more network bandwidth than if I could just directly access the points from the list of paths I have.  Is there a dependable way to calculate the ID from path, or perhaps a way to request a point by its path?
Tags (7)
  • calculate
  • endpoint
  • ids
  • paths
  • rest
  • smartconnector
  • soap
sesa180908_brid
Commander
Posted: ‎2017-12-19 02:32 PM
1254
When using the SoapEwsProvider against an SBO EWS server, the prefixes you refer to are known.
00 = ContainerItem
01 = ValueItem
02 = AlarmItem
03 = HistoryItem
11 = Property of an object represented as a ValueItem.
You might also want to take a look at the new provider which is specific to SBO (aptly named SboEwsRestProvider).  It doesn't use these EWS prefixes.  Rather it solely uses the SBO paths that you are referring to.  You'll need a seperate license for that which you can obtain from SmartConnectorServer.
sesa180908_brid
Commander
1255
00 = ContainerItem
01 = ValueItem
02 = AlarmItem
03 = HistoryItem
Posted: ‎2017-12-20 06:51 AM
1253
I'd like to test the SboEwsRestProvider, to see if it will fit our need.  Is there a developer license I can download from somewhere?
sesa180908_brid
Commander
Posted: ‎2017-12-20 06:56 AM
Josh,
The license you require is available in the License Depot of www.smartconnectorserver.com.  It is listed as "SmartConnector v2.3 CSP Add On".  There is only a single license that is good for either commercial or development purposes.
