SmartConnector supported windows and SQL version
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SmartConnector supported windows and SQL version
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Stefan_Karlsson
Lieutenant JG Stefan_Karlsson Lieutenant JG
Lieutenant JG
Posted: ‎2021-06-29 03:48 AM
1314
I need help to confirm what versions off windows and SQL that SmartConnector is supported with.
Appendix 13 in SmartConnector Installation and Configuration Guide explains this. But I can find two different versions of the same document with the same revision number 6. And those have different information.
Document on exchange declare windows server 2019 and SQL 2019: https://ecoxpert.se.com/search?documentUUID=c50286e1-cded-41b8-b881-988bf2cf2ac5&title=SmartConnecto...
But the "same" document on https://www.smartconnectorserver.com/DownloadCenter/Contents/mongoose/v2.4 only supports Windows 2016 and SQL 2016?
What is the correct information?
ardak
Posted: ‎2021-06-29 06:16 AM
1312
Hi Stefan,
This is an error on our part, I'll update the documentation as soon as possible.
SQL Server 2019, SQL Server Express 2019 and Windows server 2019 are supported.
Best regards,
Armend
ardak
1313
Hi Stefan,
Best regards,
Armend
Stefan_Karlsson
Lieutenant JG
Posted: ‎2021-06-29 10:59 PM
Hi Armend,
Thank you.
BR
Stefan
