SmartConnector processor ended unsuccessfully - "The underlying connection was closed: a connection that was expected to be kept alive was closed by the server"
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SmartConnector processor ended unsuccessfully - "The underlying connection was closed: a connection that was expected to be k...
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2020-11-08 05:20 AM
705
We have a discovery SmartConnector processor that end unsuccessfully. In the SmartConnector log file we see the following error:
Any idea what is causing the server to close the connection?
Thank you.
Mike
Replies 4
JeffBowman
Sisko
Posted: ‎2020-11-09 09:59 AM
703
Hi Michael,
Are you able to post the log? I would like to see the messages before that led up to this error. It is hard to say without this what caused this message you are seeing.
If your discovery processor is taking 2.5 hours, that of itself (assuming it simply doing discovery) may point to an issue.
Best Regards,
-Jeff
mike_meirovitz
Commander
Posted: ‎2020-11-09 09:16 PM
701
Hi Jeff,
The product in this case is the EBO-OPC server. The discovery processor needs to discover ~25,000 value items. The value items are defined in remote controllers. This is why it takes 2.5 hours.
Is there a time limit for a processor to run? If yes, can this limit be increased?
I am unable to get the log file due confidentiality.
Any idea how to proceed?
Thank you.
Mike
JeffBowman
Sisko
Posted: ‎2020-11-10 09:19 AM
699
Hi Michael,
The default time limit for a processor to run is 10 minutes, but that can be ignored by adding the ILongRunningProcess interface to your processor, which I am sure you did as it is already running for 2.5 hours. On top of that, I have run processors for months and months at a time with no issues, so this is not the problem here.
As far as the log file, this single error message doesn't tell me enough, is the database connection lost? Server connection lost? Does this happen every time you run it, and fail at the same spot? I really do need more info before I can give additional insight.
Best Regards,
-Jeff
mike_meirovitz
Commander
Posted: ‎2020-11-10 11:42 AM
Hi Jeff,
Thank you for your answer. It happens every time the processor is started. I will send you a picture of the log I got from the customer (via email due confidentiality).
Thank you.
Mike
