SmartConnector Processor not showing in Web Portal
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • SmartConnector Processor not showing in Web Portal
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Adam_Summers
Lt. Commander Adam_Summers Lt. Commander
Lt. Commander
Posted: ‎2016-07-20 07:51 AM
1586
I have a problem with a SmartConnector I've developed.
We are deploying to a clean environment with SmartConnector installed but the Web Portal will not show the processor for selection when trying to add a new processor.
I've enabled all logging levels but can't see anything in the log to assist either. Can anyone help?
sesa180908_brid
Commander
Posted: ‎2016-07-20 08:09 AM
1
1504
While deploying your SmartConnector Extension assembly to a production installation is straightforward, it is sometimes easy to forget to also include any assemblies that you may have referenced in your code that SmartConnector doesn’t know about.  Because the Portal uses reflection to analyze assemblies when it looks for Processor sub-classes, those assemblies with missing dependencies can’t be loaded and thus won’t show in the Portal.  There would be a handled exception that is logged which indicates the missing reference.
Verify that your Logging Filters allow Portal events to be written to the log.  Also verify that your Service Settings allow for a Logging Level which includes Errors. After that, retry adding your Processor and review the log files.  My guess is that you will see an error indicating a missing assembly.
sesa180908_brid
Commander
1
1505
Adam_Summers
Lt. Commander
Posted: ‎2016-07-21 01:20 AM
Thanks Mark, that got us going on the right track. The issue was not a missing assembly that the log file suggested, but a dependency of that 3rd party assembly we were referencing. Using Dependency Walker against the 3rd Party dll highlighted which other related dependencies we were missing.
