SmartConnector Execution Timeout Expired
SmartConnector Forum
Schneider Electric support forum for SmartConnector Framework - enabling custom integrations with EcoStruxure Building Operation, Power Monitoring Expert, and Power Operation.
Select a Country
  • EcoStruxure Building
  • SmartConnector
  • SmartConnector Execution Timeout Expired
JeffBowman
JeffBowman Champion
171
KarimHussain
KarimHussain Champion
60
ardak
ardak Leader
57
Back to SmartConnector Forum
esari
esari Leader
Leader
Posted: ‎2021-08-30 11:32 PM
1584
Hello
SmartConnector has stopped couple of times. There are some timeout errors. What is getting timeout?
Error below:
2021-08-24 06:45:12.8866,Error,Service,<no principal>,An error occurred while executing the command definition. See the inner exception for details.
Execution Timeout Expired. The timeout period elapsed prior to completion of the operation or the server is not responding.
The wait operation timed out
at System.Data.Entity.Core.EntityClient.Internal.EntityCommandDefinition.ExecuteStoreCommands(EntityCommand entityCommand, CommandBehavior behavior)
at System.Data.Entity.Core.Objects.Internal.ObjectQueryExecutionPlan.Execute[TResultType](ObjectContext context, ObjectParameterCollection parameterValues)
at System.Data.Entity.Core.Objects.ObjectContext.ExecuteInTransaction[T](Func`1 func, IDbExecutionStrategy executionStrategy, Boolean startLocalTransaction, Boolean releaseConnectionOnSuccess)
at System.Data.Entity.Core.Objects.ObjectQuery`1.<>c__DisplayClass7.<GetResults>b__5()
at System.Data.Entity.Infrastructure.DbExecutionStrategy.Execute[TResult](Func`1 operation)
at System.Data.Entity.Core.Objects.ObjectQuery`1.GetResults(Nullable`1 forMergeOption)
at System.Data.Entity.Core.Objects.ObjectQuery`1.<System.Collections.Generic.IEnumerable<T>.GetEnumerator>b__0()
at System.Data.Entity.Internal.LazyEnumerator`1.MoveNext()
at System.Linq.Enumerable.FirstOrDefault[TSource](IEnumerable`1 source)
at Mongoose.Service.Licensing.AntiRollbackDateTime.get_UtcNow()
,["Current WindowsIdentity is NT AUTHORITY\\SYSTEM"],
2021-08-24 06:45:21.8086,Error,Service,<no principal>,The underlying provider failed on Open.
Connection Timeout Expired. The timeout period elapsed while attempting to consume the pre-login handshake acknowledgement. This could be because the pre-login handshake failed or the server was unable to respond back in time. The duration spent while attempting to connect to this server was - [Pre-Login] initialization=1430; handshake=8176;
at System.Data.Entity.Core.EntityClient.EntityConnection.Open()
at System.Data.Entity.Core.Objects.ObjectContext.EnsureConnection(Boolean shouldMonitorTransactions)
at Mongoose.Service.Mongoose.HasValidFrameworkLicense()
2021-08-24 06:45:21.8086,Debug,WorkerManager,<no principal>,Stopping Processors,
2021-08-24 06:45:23.3399,Error,WorkerManager,<no principal>,The underlying provider failed on Open.
at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)
at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source)
at Mongoose.Service.WorkerManager.StopAllProcessors()
at Mongoose.Service.WorkerManager.ManagerLoop()
Esa
ardak
ardak Leader
Leader
Posted: ‎2021-08-31 12:42 AM
1582
Hi Esa,
It looks like Smartconnector can't connect to your database.
Is it running and can you connect to it with the provided credentials?
BR
Armend
ardak
ardak Leader
Leader
1583
Hi Esa,
BR
Armend
esari
esari Leader
Leader
Posted: ‎2021-08-31 03:52 AM
Hello Ardak
Thank you for the answer. We have installed sql express to same server so it must be server cpu usage. We will investigate more. Normally SmartConnector can access to sql.
Esa
