I can't see your images, but could you look if there is any output in %ProgramData%\SmartConnector\Logs and upload the log here?
BR
Thanks for your quick response.
Attached is Logs and Error image and setting for your view
The files you attached are not the log files but the configuration files.
The log files are here and look like this:
When you try to start the service the program output should end up there.
BR
Armend
Thanks for your guidance,
I've attached Logs file for your view.
Looking at your logs, it looks like the connection to your SQL Server is misconfigured. Please make sure the username and password you are using are correctly configured in your SQL Server.
BR
Armend
Thanks for your suggestion,
I'll check and update you,
G.G
