Smart Connector error 404
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Smart Connector error 404
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
JyKKe
Lieutenant JyKKe Lieutenant
Lieutenant
Posted: ‎2025-05-11 09:48 PM
662
Hi
Can someone help me when I do the query in Swagger and it gives me Error 404?
It's AS-B-36 and version 6.0.4.8000
Erwin-vd-Zwart
Janeway
Posted: ‎2025-05-12 10:27 PM
@JyKKe
Is this a new setup or an existing one that stopped working?
How is the endpoint setup?
Is the EWS server enabled in the EBO server?
Can you access the root of this server via get /Root?
Why do you have /sbo2/ in the request path?
Does the endpoint work at the localhost?
Erwin-vd-Zwart
Janeway
@JyKKe
