Smart Connector Endpoints And The Value State Property
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Smart Connector Endpoints And The Value State Property
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
bbradley_jaxcon
Lieutenant | EcoXpert Master bbradley_jaxcon Lieutenant | EcoXpert Master
Posted: ‎2023-01-25 09:45 AM
967
My company is using Smart Connector's Endpoint to bring values into our platform. It has mostly been working well, however we have run into a few issues brining in some Infinet set points located under an ASP. You can see what we are observing below. At a steady rate of once every 30 minutes the value drops to zero and then goes back to its previous value.
I had our software capture the the json response and sure enough the Endpoint is telling us that the value dropped to zero. I notice that the value state changed from a 4 to 0.... So I can assume that 4 may indicate an issue and 0 is good. But that is just a guess on my part and I would like to know what a state of 4 means (along with state 1, 2, and 3)
______________
"SubscriptionId": "98ed0fad-65ee-4644-98c1-34f3727aada1",
"NotificationId": "01B5ED4DF8014B38B97C98DA4EE59978",
"ChangeType": 0,
"ChangedItemId": "01/BMCJ_Pav04_01t9/Infinet Interface/NetworkA/OR2_RH_02_26/Application/SpaceSetpt",
"ChangedItemType": 1,
"ChangedAt": "2023-01-24T21:39:08Z",
"Value": "0",
"ValueState": 4,
"AlarmEventState": null,
"Id": "838B5A383D4A41F89AFA20CD4CAA7665"
 _______________
"NotificationId": "3EB5D39779164E92BBAD1C561E6FE241",
"ChangeType": 0,
"ChangedAt": "2023-01-24T21:39:26Z",
"Value": "64.6480026",
"ValueState": 0,
"Id": "47FD7DD654464C829591742C7B536D65"
bbradley_jaxcon
Posted: ‎2023-02-07 08:16 AM
Looks like we are just getting a general catch all error.... I can filter out values I guess... Wish I had a better idea on what was going on
I was able to find the documentation for all the different states (picture above)
bbradley_jaxcon
