Sample Smartconnector Restful API client
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Sample Smartconnector Restful API client
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa237670_brid
sesa237670_brid Schneider Alumni (Retired)
Posted: ‎2018-02-12 07:11 AM
2034
Can you share the SOAP rest Provider sample project Github location ? I am trying to do GET/SET for values in EBO using smartconnectior Restful framework from web application/services.
Adam_Summers
Lt. Commander Adam_Summers Lt. Commander
Lt. Commander
Posted: ‎2018-02-12 07:18 AM
The samples projects are hosted here GitHub - BuildingsLabs/SmartConnectorSamples: Sample projects for SmartConnector
Replies 5
Adam_Summers
Lt. Commander
JeffBowman
Sisko
Posted: ‎2018-02-12 07:21 AM
1930
Hi Neeraj,
On top of what is in the samples that Adam showed above. This blog post shows how to create and setup a C# client in your environment.
Generate client in Visual Studio for SmartConnector RESTful Endpoints
-Jeff
sesa180908_brid
Commander
Posted: ‎2018-02-12 07:24 AM
1930
There is REST client sample code in the aforementioned project as well.
sesa237670_brid
Posted: ‎2018-02-12 08:16 AM
Is 'CustomRestExtension' that project ?   I looked at the 'SmartConnector RESTful EWS Gateway' documentation. Just wondering what you recommend to be good starting point to develop a simple test application to read/write value from EBO using Smartconnector restful api ? IS their any webinar or tutorial ?
JeffBowman
Sisko
Posted: ‎2018-02-12 08:42 AM
Hi Neeraj,
The project you are looking for is Ews.RestExtensions.Client.
The REST endpoints is simply a web service; meant to be consumed by any client that can consume a web service.
The documentation for this is on SmartConnectorServer in the download center. Look at the 'SmartConnector RESTful EWS Gateway.pdf'
If you have any specific questions about how to use the web service from a conceptual stand point, I would be happy to help, but as far as generic code, that would not exist, as it is meant to be consumed by any programming language.
-Jeff
