I have been looking to see if there has been any testing results on the performance of the RESTful EWS Gateway.
I have seen there is a TVDA "EWS Serve Performance for SmartStruxure Solution v1.8.1 - Integration Guide" which provides performance result for EWS with some common configurations of ES, AS-P and sub-lans.
Is there any such document for the RESTful EWS Gateway that I have not been able to find?
I am looking for this information as we have project require exposure of the BMS (EBO 2.0.1) to an Integration Platform which requires access to all points, alarms and trend data for specific polling periods.
Hi Christopher,
There are no documents about EWS RESTful gateway performance. But if you are using the SoapEwsRestProvider. It uses EWS behind the scenes to get data from EBO. So you should expect similar performance to what was outlined in the TVDA you referenced.
-Jeff
Hi Jeff,
Thanks for the confirmation. The intention was to use the SoapEwsRestProvider, not the Sbo.
Chris
