Processor,<no principal>,Alarm Push Processor, Reading alarms from http://localhost:80/EcoStruxure/DataExchange with no last update
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Processor,<no principal>,Alarm Push Processor, Reading alarms from http://localhost:80/EcoStruxure/DataExchange with no last ...
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2024-10-07 12:07 AM
We have a SmartConnector extension that pushes alarms from the EBO to our system. The processor running using a 2-3 seconds scheduler. In most cases it runs OK, and when running you can see this line in the SmartConnector log file:
Debug, Processor,<no principal>,Alarm Push Processor, Reading alarms from http://localhost:80/EcoStruxure/DataExchange with last update: b45c427b-c3b5-4405-bd95-c1bb1188257a|10998674,
From time to time, we see this errors:
024-10-01 17:14:56.3105,Debug,Processor,<no principal>,Alarm Push Processor, Reading alarms from http://localhost:80/EcoStruxure/DataExchange with last update: b45c427b-c3b5-4405-bd95-c1bb1188257a|10998674,
2024-10-01 17:44:56.3471,Error,Processor,<no principal>,The operation has timed out.
Server stack trace:
at System.Net.GZipWrapperStream.Read(Byte[] buffer, Int32 offset, Int32 size)
at System.ServiceModel.Channels.HttpInput.WebResponseHttpInput..ctor(HttpWebResponse httpWebResponse, IHttpTransportFactorySettings settings, ChannelBinding channelBinding)
at System.ServiceModel.Channels.HttpChannelUtilities.ValidateRequestReplyResponse(HttpWebRequest request, HttpWebResponse response, HttpChannelFactory`1 factory, WebException responseException, ChannelBinding channelBinding)
at System.ServiceModel.Channels.HttpChannelFactory`1.HttpRequestChannel.HttpChannelRequest.WaitForReply(TimeSpan timeout)
at System.ServiceModel.Channels.RequestChannel.Request(Message message, TimeSpan timeout)
at System.ServiceModel.Dispatcher.RequestChannelBinder.Request(Message message, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Ews.Client.IDataExchange.GetUpdatedAlarmEvents(GetUpdatedAlarmEventsRequest1 request)
at Ews.Client.DataExchangeClient.Ews.Client.IDataExchange.GetUpdatedAlarmEvents(GetUpdatedAlarmEventsRequest1 request)
at Ews.Client.DataExchangeClient.GetUpdatedAlarmEvents(GetUpdatedAlarmEventsRequest request)
at Ews.Client.EwsClient.ExecuteAndLogCall[TRequest,TResponse](String methodName, TRequest request, Func`2 methodToLog, Boolean includeMetadata)
at Ews.Client.EwsClient.ExecuteAndLogCall[TRequest,TResponse](String methodName, TRequest request, Func`2 methodToLog)
at Ews.Client.EwsClient.GetUpdatedAlarmEvents(String lastUpdate, Nullable`1 priorityFrom, Nullable`1 priorityTo, String moreDataRef, String[] types)
at Mongoose.Service.Cache.ManagedEwsClient.<>c__DisplayClass32_0.<GetUpdatedAlarmEvents>b__0(EwsClient x)
at Mongoose.Service.Cache.ManagedEwsClient.ManageCall[T](IEndpoint endpoint, Func`2 method, Nullable`1 callVersion)
at Mongoose.Service.Cache.ManagedEwsClient.GetUpdatedAlarmEvents(IEndpoint endpoint, String lastUpdate, Nullable`1 priorityFrom, Nullable`1 priorityTo, String moreDataRef, String[] types, Nullable`1 callVersion)
at Mongoose.Process.Ews.AlarmItemReader.ReadData()
Starting the error above, all calls returns without last update. See below.
Debug, Processor,<no principal>,Alarm Push Processor, Reading alarms from http://localhost:80/EcoStruxure/DataExchange with no "last update". See below.
2024-10-01 17:53:26.5565,Debug,Processor,<no principal>,UCME Alarm Push Processor,Reading alarms from http://localhost:80/EcoStruxure/DataExchange with no last update.,
2024-10-01 17:56:33.0923,Debug,Processor,<no principal>,UCME Alarm Push Processor,Reading alarms from http://localhost:80/EcoStruxure/DataExchange with no last update.,
2024-10-01 17:59:39.6659,Debug,Processor,<no principal>,UCME Alarm Push Processor,Reading alarms from http://localhost:80/EcoStruxure/DataExchange with no last update.,
2024-10-01 18:02:46.2659,Debug,Processor,<no principal>,UCME Alarm Push Processor,Reading alarms from http://localhost:80/EcoStruxure/DataExchange with no last update.,
2024-10-01 18:05:52.8253,Debug,Processor,<no principal>,UCME Alarm Push Processor,Reading alarms from http://localhost:80/EcoStruxure/DataExchange with no last update.,
2024-10-01 18:08:59.3865,Debug,Processor,<no principal>,UCME Alarm Push Processor,Reading alarms from http://localhost:80/EcoStruxure/DataExchange with no last update.,
2024-10-01 18:12:06.0787,Debug,Processor,<no principal>,UCME Alarm Push Processor,Reading alarms from http://localhost:80/EcoStruxure/DataExchange with no last update.,
See the attached SmartConnector log file.
Any idea what is causing this error?
Thanks.
Mike
2024-10-01.log
Replies 0
