PME and SmartConnector
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • PME and SmartConnector
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
KarimHussain
Commander KarimHussain Commander
Commander
Posted: ‎2018-08-20 08:34 AM
2297
Is it possible to add a SmartConnector to a PME system?
What I want to achieve is to get data from a RESTful API, store it in history items / trend logs and get them into PME. So I want to consume data from a 3rd party cloud service and get it into PME.
Or is it a better aproach to have the SmartConnector integrated to SBO and then use the ETL tool to get the data into PME?
JeffBowman
Sisko
Posted: ‎2018-08-20 08:51 AM
1
2270
Hi Karim,
As far as getting data into PME, the only thing I know about that can do this for sure is the ETL. That said, in theory if you know the database scheme for PME, you can write a Smart Connector extension that pushes data directly to the database yourself.
-Jeff
JeffBowman
Sisko
1
2271
Hi Karim,
-Jeff
KarimHussain
Commander
Posted: ‎2018-08-20 08:56 AM
Thanks, I will most probably go for the SBO and ETL alternative then 🙂
