Object does not match target type.
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Object does not match target type.
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa237670_brid
sesa237670_brid Schneider Alumni (Retired)
Posted: ‎2018-08-21 10:52 AM
1378
Hi Jeff,
When I am deploying my endpoints on the SmartConnector Portal, I am getting following error on Validation or in running the endpoints. What is the best way to find the cause of this error ? Following is the only useful information in the log.
Starting REST Provider http://127.0.0.1:8099,
2018-08-21 13:44:40.1744,Error,Service,<no principal>,Object does not match target type.
   at System.Reflection.RuntimeMethodInfo.CheckConsistency(Object target)
   at System.Reflection.RuntimeMethodInfo.InvokeArgumentsCheck(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
   at System.Reflection.RuntimePropertyInfo.GetValue(Object obj, BindingFlags invokeAttr, Binder binder, Object[] index, CultureInfo culture)
   at System.Reflection.RuntimePropertyInfo.GetValue(Object obj, Object[] index)
   at Mongoose.Common.ObjectExaminer.GetObjectMemberValue(Object item, MemberInfo member)
   at Mongoose.Common.ObjectExaminer.TraverseObject(ITraversable node, ITraversable parentNode, Int32 currentDepth, Int32 maxDepth, ProcessObjectDelegate callBack)
   at Mongoose.Common.ObjectExaminer.GetTraversableItems(ITraversable startingNode, Int32 maxDepth)
   at Mongoose.Common.GenericValidator.ValidateItem(ITraversable item, Int32 maxDepth)
   at Mongoose.Common.ExtensionMethods.ValidateInstance(IDerivedFromConfiguration item)
   at Mongoose.Service.Mongoose.SpinUpRestProvider(RestConfiguration configuration, MongooseDbContext db)
Thanks!
Neeraj Tomar
JeffBowman
Sisko
Posted: ‎2018-08-23 11:26 AM
Hi Neeraj,
I took a look into this, and its possible this can occur if you have two classes with the same namespace and class name in multiple different assemblies copied in the Smart Connector directory.
Make sure that your namespaces on all your extension are unique and this error should go away.
-Jeff
JeffBowman
Sisko
Hi Neeraj,
-Jeff
