The setpoints connected to the DDC MNL is going to 0 automatically upon power reset what could be the possible cause of it and is there any reference document for that concern.
You can create a Priority Input blocks on the MNL logic to hold the last value sent from SNVT
On this example, you can connect the nvi SNVT on I1 position
