Is there a definitive list for the numbers at the beginning of StruxureWare path when using the SmartConnector Endpoint
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Is there a definitive list for the numbers at the beginning of StruxureWare path when using the SmartConnector Endpoint
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
bbradley_jaxcon
Lieutenant | EcoXpert Master bbradley_jaxcon Lieutenant | EcoXpert Master
Posted: ‎2020-07-20 05:49 AM
1570
Is there a definitive list for the numbers at the beginning of StruxureWare path when using the SmartConnector Endpoint?
For example
00/  - Seems to be a container
01/ - Present value
JeffBowman
Sisko
Posted: ‎2020-07-20 08:15 AM
Hi Brian,
I can't say that there is a definitive list, but here is what I know, and most likely the majority if not all of them.
00 = Container Item
10 = A Value item that is a property of a Container Item
20 = Alarm Item that is a property of a Container Item
30 = History item that is a property of a Container Item
01 = Value Item
11 = Value Item that is a Property of another Value item (e.g. the priority array elements of a BACnet point)
21 = Alarm Item that is a property of a Value Item
31 = History Item that is a property of a Value Item
02 = Alarm Item
12 = Value Item that is a property of an Alarm Item
22 = Alarm item that is a property of another Alarm item
32 = History Item that is a property of an Alarm item
03 = History Item
13 = Value Item that is a property of an History Item
23 = Alarm item that is a property of a History item
33 = History Item that is a property of an another History item
For the vast majority of situations, you will be using 01, 11, 02, and 03. The others are honestly rare, and some of them I haven't actually seen, but included here for completion.
Best Regards,
-Jeff
JeffBowman
Sisko
Hi Brian,
00 = Container Item
01 = Value Item
02 = Alarm Item
03 = History Item
Best Regards,
-Jeff
