Is it possible to start a SmartConnector extension Processor programatically?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Is it possible to start a SmartConnector extension Processor programatically?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2019-05-13 10:34 PM
807
Thanks.
Mike
JeffBowman
Sisko
Posted: ‎2019-05-14 05:27 AM
1
804
Hi Michael,
It depends on what you mean by programatically.
It is possible to start a processor from another processor. (See section 9.9 in the Smart Connector Developer's guide). However, this assumes you are running the code from Smart Connector. If you are talking about executing a Smart Connector processor via a web service, then No, there is nothing built into Smart Connector that allows this. But in theory you could write a custom REST endpoint in Smart Connector that leverages the ActionBroker api (described in section 9.9).
9.9 Coordinating Actions
From time to time, circumstances may arise in your Extension development where one Processor needs to spawn another. SmartConnector supports this functionality via a dependency injected instance of the IActionBroker interface. Additionally, all Processor and EWS Server Processor sub-classes have an ActionBroker property available to them. See Figure 86 for an example.
See Mongoose.Common.IActionBroker interface for available properties and methods.
Best Regards,
-Jeff
JeffBowman
Sisko
1
805
Hi Michael,
Best Regards,
-Jeff
mike_meirovitz
Commander
Posted: ‎2019-05-14 11:53 AM
Thank you Jeff!
Mike
