IBM Maximo integration with EcoStruxure
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • IBM Maximo integration with EcoStruxure
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Evren
Lt. Commander Evren Lt. Commander
Lt. Commander
Posted: ‎2018-11-26 10:35 PM . Last Modified: ‎2022-04-28 06:54 AM
1
1915
Looking for options to integrate with IBM Maximo (&Tivoli) solution. I would like to know if anybody has any experience with this integration.
Summary of the Integration Goals:
IBM Maximo software is used for work order process. Work orders shall be created on Maximo also can be seen at EcoStruxure. Maximo work orders can be closed form EcoStruxure Building Operation,
IBM Tivoli software is used for event management. Data connected to EcoStruxure Building Operation and i.e. connection loss, temperature alarms and abnormalities can be monitored from Tivoli software.
The integration shall allow physical assets from BMS (or ISP) database to be connected to IBM pool; the asset list can be uploaded or scanned periodically by IBM.
Tags (4)
  • IBM
  • integration
  • Maxima
  • Tivoli
sesa116095_brid
Ensign sesa116095_brid Ensign
Ensign
Posted: ‎2018-11-27 08:52 AM
The U.S. Solutions Engineering Team has recently developed an EBO 2.0 Smart Connector Extension designed to map EBO Alarms to Maximo Assets for Work Order creation and updates. Alarm categories are used to configure which alarms are delivered to Maximo. Configuration spreadsheets are used to map each alarm to a Maximo Site, Owner and Asset ID. Multiple points can be mapped to the same Asset ID. ALM’s & RTN’s create (or update) Maximo Work Orders by storing the TimeStamp, ALM/RTN Message, Point Value and Point Path in the Work Order's long description. All Work Order processing and management is performed through Maximo. For more information, email COE@Schneider-Electric.com
Ellis
Tags (2)
  • cmms
  • Maximo
sesa116095_brid
Ensign
Ellis
Tags (2)
  • cmms
  • Maximo
