I am unable to login to SmartConnector - can I reset the password?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • I am unable to login to SmartConnector - can I reset the password?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2018-11-27 09:21 AM
2076
I am unable to login to SmartConnector. I tried to change the data in the Dbo.AspNetUsers table field LockoutAndDateUtc to NULL.
Is there a way to reset the password?
Thank you.
Mike
JeffBowman
Sisko
Posted: ‎2018-11-27 12:53 PM
2071
Hi Michael,
The below is how you 'reset' your password. Keep in mind, this will also remove all Smart Connector users as well. This will reset the users back to its default settings.
  • Stop the service
  • If the database configuration settings for “SmartConnectorDb” and “SmartConnectorUserDb” are referencing DIFFERENT databases, then simply delete the database that “SmartConnectorUserDb” is pointing to.
  • If the database configuration settings for “SmartConnectorDb” and “SmartConnectorUserDb” are referencing THE SAME databases, then drop all tables that start with “AspNet” (there should be five of them: AspNetRoles, AspNetUserClaims, AspNetLogins, AspNetUserRols, and AspNetUsers).  I’m not sure of the exact order but I do know there will be some FKEY constraints so if you get an FKEY error delete the referenced table first and retry.
  • Once the “users” tables/database is deleted, re-start the service.  The Service will recreate the Users DB with the default admin and password.
-Jeff
JeffBowman
Sisko
2072
Hi Michael,
  • Stop the service
-Jeff
benware
Lieutenant | EcoXpert Master benware Lieutenant | EcoXpert Master
Posted: ‎2024-01-31 02:50 AM . Last Modified: ‎2024-01-31 03:00 AM
1614
Hi Jeff, or anyone who hasn't retired,
Where are these datebase configurations located ?
mike_meirovitz
Commander
Posted: ‎2024-01-31 11:12 PM
Hi Ben,
The easiest solution is to uninstall and reinstall SmartConnector.
Mike
