How to get the nuget api key for SmartConnector's public libraries?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • How to get the nuget api key for SmartConnector's public libraries?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
XiangfengSU
Lieutenant JG XiangfengSU Lieutenant JG
Lieutenant JG
Posted: ‎2018-05-17 07:08 PM
6086
I hava a SmartConnector Server account and myget account, but how can I get the API KEY for SmartConnector's public libraries?
JeffBowman
Sisko
Posted: ‎2018-05-18 07:03 AM
6052
Hi Xiangfeng,
You must sign up as a developer and create a tenant on www.smartconnectorserver.com. When you do that, and the request has been accepted, you will receive an invitation link that allows you to gain access to the NuGet feed.
If you have already done this, then check your email address that you used to sign up on smartconnectorserver.com
If you didn't get an invite, send me the email address you want me to send the invitation to, and I will send you the invitation manually.
-Jeff
Replies 25
JeffBowman
Sisko
6053
Hi Xiangfeng,
-Jeff
XiangfengSU
Lieutenant JG
Posted: ‎2018-05-20 08:03 PM
6049
Hi Jeff
    I have already done that. My email address: xiangfeng.su@schneider-electric.com.
SU
JeffBowman
Sisko
Posted: ‎2018-05-21 06:20 AM
6049
Hi Su,
I have manually sent your email address an invite.
-Jeff
XiangfengSU
Lieutenant JG
Posted: ‎2018-05-21 05:50 PM
Hi, Jeff
I have received your invitation. Thanks.
SU
Posted: ‎2020-03-09 08:00 PM
6035
Hi Jeff,
i have created a tenant on ww.smartconnectorserver.com but unsure if I  missed the invite link for the NuGet API key. Would you be able to send me an invite again? Thank you so much.
JeffBowman
Sisko
Posted: ‎2020-03-10 06:29 AM
6026
Hi!
What is your email address?
Best Regards,
-Jeff
Posted: ‎2020-03-10 02:47 PM
6022
Hi Jeff, my email is anqi.he@se.com
Thank you!
JeffBowman
Sisko
Posted: ‎2020-03-11 07:13 AM
6020
Hi Anqi,
If you don't get the invite please let me know. Also check your Junk folder.. Kind of curious if it got sent there.
Best Regards,
-Jeff
Posted: ‎2020-03-11 08:37 PM
6016
Hi Jeff,
Strangely I haven't received the invite email, it's not in the junk box either. I've had an email from SmartConnector Server <noreply@smartconnectorserver.com> that says the request has been approved and a tenant was created, but there's no email from MyGet.
JeffBowman
Sisko
Posted: ‎2020-03-12 06:24 AM
6013
Hi Anqi,
You are actually send the second SE employee that mentioned they are not getting the invite. So I am wondering if for some reason our Email server is filtering out these invites..
I was able to get around the other one, by sending it to an alternate email address. Do you have a non-SE email address I can try and send the invite too?
Best Regards,
-Jeff
Posted: ‎2020-03-15 03:49 PM
6009
Hi Jeff, can you send it to anqian59@gmail.com? Thank you so much!
JeffBowman
Sisko
Posted: ‎2020-03-16 06:43 AM
6005
All set! Please let me know if you didn't get it.
Best Regards,
-Jeff
Anawat
Lt. Commander Anawat
Lt. Commander
Posted: ‎2020-06-18 03:17 AM
5994
@JeffBowman
Could you please also send invitation link to me?
My email is anawat.su@esi.co.th
Thanks in advance.
Tags (2)
  • smartconnector
JeffBowman
Sisko
Posted: ‎2020-06-18 06:44 AM
5991
Hi!
You should have been sent the invite once I approved your tenant, which i did this morning.
Please let me know if you didn't get the invite.
Best Regards,
-Jeff
Anawat
Lt. Commander
Posted: ‎2020-06-18 09:04 AM
5987
Hi Jeff,
I've checked my inbox. I still haven't get any email from you or myget.
JeffBowman
Sisko
Posted: ‎2020-06-18 09:07 AM
5985
I've just manually resent the invite. Please let me know if you receive it! Also, its possible it get sent to Junk folder, so check there as well.
Best Regards,
-Jeff
Anawat
Lt. Commander
Posted: ‎2020-06-18 09:22 AM
Hi Jeff,
Yes, i got it. Thank you for kind support.
TomeLu
Commander | EcoXpert Master TomeLu Commander | EcoXpert Master
Posted: ‎2021-11-16 01:20 AM
5945
hi @JeffBowman
My email is  " tome.lu@barcol.com.tw "
ardak
Posted: ‎2021-11-16 01:42 AM
6
5942
@TomeLu
Jeff is no longer with SE.
I have sent you an invitation.
BR
Armend
dsantillan
Lieutenant dsantillan
Lieutenant
Posted: ‎2021-11-22 08:43 AM
5932
Hello Armend,
I requested a Tenant last week on SmartConnectorServer, but I have not received an invitation.
My email address is dsantillan@zavarsa.com. Can you help?
Thank you,
Douglas
ardak
Posted: ‎2021-11-22 09:05 AM
5929
Hi Douglas,
I've invited you manually, let me know if you haven't received the link.
BR
Armend
dsantillan
Lieutenant
Posted: ‎2021-11-22 09:30 AM
Hello Armend,
Thank you, got email from MyGet already.
Best regards,
Douglas
dsantillan
Lieutenant
Posted: ‎2021-11-23 10:33 AM
5921
Hello Armend,
I am trying to follow the Smart Connector Developer Guide
Once I get to adding the NuGet reference, Visual Studio does not get the list and throws this error:
[smartconnectorserver.com] The V2 feed at 'https://www.myget.org/F/mongoose/auth/MY API KEY/api/v2/Search()?$filter=IsLatestVersion&searchTerm=''&targetFramework='net472'&includePrerelease=false&$skip=0&$top=26&semVerLevel=2.0.0' returned an unexpected status code '403 Forbidden'.
I am using Visual Studio 22 Version 17.0.1. I have tried both .net 4.8 and 4.7 frameworks.
Please point me in the right direction.
ardak
Posted: ‎2021-11-23 09:30 PM
5918
You seem to have forgotten to change "MY API KEY" to your api key, which you should have gotten from myget.
BR
Armend
dsantillan
Lieutenant
Posted: ‎2021-11-24 08:46 PM
Hello Armend,
In case somebody else encounters the 403 error, this is how it was resolved:
Downgraded to Visual Studio 2019. And then re-claimed using the code included on the invitation.
While logged in to MyGet, mongoose - Feed details, FEED DETAILS, there is a pre-authenticated V3 URL that should be used with Visual Studio 2015 and later.
Dependencies and Target Framework info for each package is also available from the Packages link.
Thank you,
Douglas
