How to check if processor is running or not?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • How to check if processor is running or not?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
ahmet191
Ensign ahmet191
Ensign
Posted: ‎2022-11-12 04:22 AM
1133
There is bool value for EWS Server to check if it is running as "DataAdapter.Server.IsRunning" but i couldn't found one yet for processors. I know there is this information on the "dbo.ThreadStates" table. But i couldn't find a way to reach this table through DataAdapter or some other way. I wonder how can i get this info from db? Thanks in advance.
Note: I have my own ways to check but still looking for appropriate way to check.
Erwin-vd-Zwart
Janeway
Posted: ‎2022-11-14 12:42 AM
See this sample code: https://github.com/BuildingsLabs/EboIoTEdgeConnector
The setup processor writes his process ID in the cache so another processor can retrieve this ID of the process and than with the actionbroker you can request the status of other running processes (when knowing the process ID).
BR,
Erwin
Erwin-vd-Zwart
Janeway
BR,
Erwin
