How can I enable potential customers to download a 30 days license for our extension?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • How can I enable potential customers to download a 30 days license for our extension?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2020-11-30 12:37 PM
1734
We would like to enable potential customers to download a 30 days license for our extension. It should be similar to the SmartConnector Evaluation license. Can you explain how this should be done?
Thank you.
Mike
JeffBowman
Sisko
Posted: ‎2020-12-04 12:20 PM
1718
Hi Michael,
Clicking on the name of the extension item in the License Depot (should be blue link), will bring you to it's detail page. You can delete it from there.
Best Regards,
-Jeff
Replies 6
JeffBowman
Sisko
Posted: ‎2020-11-30 12:56 PM
1732
Hi Michael,
I would recommend referring to the FAQ on Smart Connector Server.
https://www.smartconnectorserver.com/Faq
Specifically, the section about License Templates. You are able to create a license template that creates a license that expires after 30 days. You then create licenses from that template.
Best Regards,
-Jeff
mike_meirovitz
Commander
Posted: ‎2020-11-30 01:21 PM
1729
Hi Jeff,
Thank you. I needed to make the template public to see the extra fields.
Now, after the template is public, what should I do to make it visible in the License Depot?
Thanks.
Mike
@JeffBowman
JeffBowman
Sisko
Posted: ‎2020-11-30 01:22 PM
1727
Hi Michael,
Click on the License Depot, and then click "Add Item". You will be able to select your template.
Best Regards,
-Jeff
mike_meirovitz
Commander
Posted: ‎2020-12-01 03:52 AM
1723
Hi Jeff,
How can I delete the License Depot item and start a new one?
Thank you.
Mike
JeffBowman
Sisko
1719
Hi Michael,
Best Regards,
-Jeff
mike_meirovitz
Commander
Posted: ‎2020-12-05 10:43 PM
Thank you Jeff!
Mike
