Following error occurs on some trend logs with Get TrendSamples
Some logs works as expected but some return code 500 and the error message.
But if I rename the log to something else in Workstation and try again with the new id it works just fine?
Any help or ideas how to fix this without renaming logs?
Same issue?
I believe that a newer version fixed my issue. You can also try clearing your in memory cache. See screen shot.
It is a similar issue yes. But we already had newer version than that post.
Is there anything I should know before clearing the memory cache? Or is it safe to do? I mean that there are multiple users using that Smart Connector.
I can't answer that, not knowing your setup, but it is unlikely to cause any issues.
