EWS server values are in Error state after the EWS setup processor is running
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • EWS server values are in Error state after the EWS setup processor is running
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2021-03-12 11:23 AM
1084
We have an EWS server that has two processors: Setup and Update.
The Setup processor creates all the EWS values and then it starts the Update processor.
In the first time we host the EWS server in the EBO, the values are displayed in the EBO with no problems.
After restarting the computer, the Setup processor is executed ("Runs On Start = True") and then it starts the Update processor. The values in the EWS server (in the SmartConnector portal) looks fine, but in the EBO they show "Error".
Any idea why?
Do we have to re-host the EWS server each time the Setup processor is executed?
Thank you.
mike_meirovitz
Commander
Posted: ‎2021-03-13 12:41 AM
Hi Jeff,
Thank you. You may close this case.
Mike
mike_meirovitz
Commander
Hi Jeff,
Mike
