EWS Server port number?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • EWS Server port number?
JeffBowman
Sisko JeffBowman Sisko
164
ardak
34
sesa180908_brid
34
mike_meirovitz
Commander mike_meirovitz
21
Back to SmartConnector Forum
mike_meirovitz
Commander
Posted: ‎2022-06-03 02:23 AM
2897
When developing an EWS server, should the EWS communication port number be always 5,300? What if there are several EWS servers installed on the same computer, can all of them use the same port? If not, should each EWS server have its own port number defined in the SmartConnector extension source code?
Thanks.
Mike
ardak
Posted: ‎2022-06-03 04:18 AM
Yes!
ardak
Posted: ‎2022-06-03 02:32 AM
2892
Hi Mike,
You can use whatever port you want for your EWS servers. It does not have to be hard coded in the source code, you can set it as a configuration parameter in a "setup" style processor for example.
BR
Armend
mike_meirovitz
Commander
Posted: ‎2022-06-03 03:03 AM
2886
Hi Armend,
See the attached screen capture. Do you mean here?
Thanks.
Mike
ardak
Yes!
