EBO-OPC Server Integration
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • EBO-OPC Server Integration
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Control-See Software Solutions Ltd
OPC Server for Building Operations
Back to SmartConnector Forum
AdamC31
Crewman AdamC31
Crewman
Posted: ‎2023-05-16 05:30 AM . Last Modified: ‎2025-05-29 11:31 PM
3104
Hi All,
Currently in the process of integrating a number of EBO sites (5 sites) via the EBO-OPC Server product from ControlSee (The product is available on Controlsee website) into a central monitoring systems (Aveva). If in a years time site no.1 add a new chiller for instance and there are new alarms configured on the EBO headend. Does the ControlSee application automatically pick these points up or do these also need configuring/engineering?
TIA!
Adam
  • Thumbnail of OPC Server for Building Operations
View products (1)
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2023-05-16 05:43 AM
3099
Hi Adam,
When you add a new alarm in the EBO, there is  o need for configuration/engineering. All you need is to add the new alarm in the OPC Client (Aveva in your case). For example, if the alarm id is "/Server 1/Values/Change of State Alarm", you need to add this OPC item in Aveva - "/Server 1/Values/Change of State Alarm.Alarm".
Michael
Replies 4
mike_meirovitz
Commander
3100
Hi Adam,
Michael
AdamC31
Crewman AdamC31
Crewman
Posted: ‎2023-05-17 01:46 AM
Thank you very much for the confirmation
mike_meirovitz
Commander
Posted: ‎2023-05-18 04:00 AM
Al,
My mistake. You need to do run the Discovery processor in SmartConnector to discover the newly added alarms.
Mike
killu7
killu7
Cadet
Posted: ‎2023-05-24 06:19 AM
Right click on the OPC DataHub system-tray icon and choose Properties. In the Properties window, select OPC .
regards: ultrasonic pest repeller side effects
