Hi Michael,
Since the web client requires an installed EBO server and is installed along with then. As long as that EBO server ES you can install Smart Connector on the same computer as the ES. If you are asking if Smart Connector needs to be installed on the same PC as EBO. From a purely communication standpoint. The answer is no it can be installed anywhere since EWS is just a web service.. As long as the server where the web service is hosted can be reached by whenever Smart Connector is installed. You will be fine.
-Jeff
Hi Michael,
-Jeff
Thank you Jeff!
