Posted: 2017-08-14 05:22 AM
I have previously created a smart connector with a customSetValueProcessor and all works fine, I have started a new project and added my own customSetValueProcessor, but I can't debug the code as it never get called. I have gone over the developer guide and followed it's instructions but still no luck.
James,
Can you compare what you are doing with the sample project found here: GitHub - BuildingsLabs/SmartConnectorSamples: Sample projects for SmartConnector
In that case, I'm also using a CustomSetValuesProcessor. The Test project has a fixture which allows testing of the custom processor.
Let me know if you are still stuck after comparing what you are doing with the sample.
