Any Way to Access Historical Data - Smart Connector
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Any Way to Access Historical Data - Smart Connector
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Lydia
Lieutenant | EcoXpert Master Lydia Lieutenant | EcoXpert Master
Posted: ‎2019-10-31 01:19 PM
1640
I currently am working on a project to produce trend graphs. I will be obtaining my data from SmartConnector to do this. I would like to figure out a way in which I would not have to produce a large history CSV/JSON/XML on my end since that would increase the time due from writing to a file and then having my software read from said file.
Is there any way to access historical data directly from SmartConnector? If so, how would I be able to do that?
Tags (8)
  • access
  • connector
  • data
  • historical
  • history
  • present
  • smart
  • smartconnector
JeffBowman
Sisko
Posted: ‎2019-10-31 01:39 PM
1
1638
Hi Lydia,
Look at the ManagedEwsClient (EwsClient), at the GetHistory function. This allows you to pull Historic Records out of EBO if you know a trend log's ID :).
Best Regards,
-Jeff
JeffBowman
Sisko
1
1639
Hi Lydia,
Best Regards,
-Jeff
Lydia
Posted: ‎2019-11-01 01:29 PM
Thank you so much. I'll look into it. 🙂
