Alarm from SmartConnector DB to EBO
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Alarm from SmartConnector DB to EBO
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa450478_brid
sesa450478_brid Schneider Alumni (Retired)
Posted: ‎2018-06-08 05:59 AM
4
1184
Hello to all,
I am trying to activate the allarms in EBO trought the SmartConnector methods "ActivateAlarmItem" or "ModifyAlarmItemState" (see Attachment "AlarmClass").
But I have the following error:
  • "An entity object cannot be referenced by multiple instances of IEntityChangeTracker.."
  • "the method or operation you are performing is not allowed.."
Do you have a working example with alarms?
Thanks in advanced for your help
Michele
AlarmClass.cs.zip
sesa450478_brid
Posted: ‎2018-06-12 05:05 AM
1116
Hello to all,
I found the problem/bug in my code and now everything works.
Michele
Replies 4
Mike_Bielby
Lt. Commander Mike_Bielby Lt. Commander
Lt. Commander
Posted: ‎2018-06-11 02:04 PM
1116
Hi Michele, Can you check out a similar request (Check out 'Alarm transfer to EBO from SmartConnector DB using the EWS Server' in Exchange Community) in this forum to see if you can get your answer from that. If not we can look into it.
Thanks for using the forum.
Mike
sesa450478_brid
Posted: ‎2018-06-12 12:39 AM
Hi Michael,
Hi Michael,
I saw the request "Alarm transfer to EBO from Smart Connector DB using the EWS Server" but unfortunately the request is not the same.
Thanks in advance for your help
Michele
sesa450478_brid
1117
Hello to all,
Michele
JeffBowman
Sisko
Posted: ‎2018-06-13 06:33 AM
Thanks for letting us you know found the problem!
-Jeff
