API integration with VergeSense Occupancy Monitoring System & IAQ Sensors
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • API integration with VergeSense Occupancy Monitoring System & IAQ Sensors
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Perry-Soe
Ensign Perry-Soe
Ensign
Posted: ‎2022-01-10 06:50 PM
973
Let me ask a few questions about smart connector. Don't be mind if my questions are too basic since I'm a new comer.
(1) I need to integrate my EBO with VergeSense(https://vergesense.com/) Occupancy Monitoring System by API. Do I need to use Smart Connector for this integration? If so, could I get any supporting document on this type of integration?
(2) Sam API integration for IAQ Sensors whose data are stored in the third party cloud(https://qlear.io/web/knowledge), we can get the API token for this integration from them? Is smart connector also needed for this integration? If so, would I need two licenses or one license is needed for both of these 2 different integrations?
(3) If smart connector doesn't support this kind of API integration, which other integration method could I look for to interface with EBO?
Thanks in advance.
ardak
Posted: ‎2022-01-12 01:04 AM
This could be done in Smartconnector. There is some indication that someone at some point has started working on a VergeSense extension, but I haven't found the creator.
I took a quick look at the qlear.io API and it looks like everything you'd need is there, so an extension for that is possible aswell. I don't think an extension exists today.
So yes, it's possible, but there would be some work required.
BR
Armend
