Configuring network connections in the ETL import database
Setting up an ETL configuration
  • EcoStruxure IT Help Center
  • IT Advisor
  • ETL - Extract Transform Load
  • Setting up an ETL configuration
  • Configuring network connections in the ETL import database
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Setting up an ETL configuration
  • Mark as Read
Sisko JLehr Sisko
‎2023-11-10 12:14 PM
on ‎2023-11-10 12:14 PM
In an ETL configuration, allowed IP addresses that can access the database can be configured as:
List
10.1.1.1,10.1.1.2,10.1.1.3 (comma separated)
Range
10.1.1.1-10.1.1.30 (all IP addresses between 10.1.1.1 and 10.1.1.30)
Mask
10.1.1.0/24 (all IPs in the sub network 10.1.1.x)
10.1.0.0/16 (all IPs in the sub network 10.1.x.x)
10.0.0.0/8 (all IPs in the sub network 10.x.x.x)
0.0.0.0/0 (all IPs - no restriction)
See Subnet mask cheatsheet
