Edit Report Criteria option
Sensor History reports
Select a Country
  • EcoStruxure IT Help Center
  • DCE reports
  • Sensor History reports
  • Edit Report Criteria option
  • Mark as Read
  • Table-format reports
  • Summary-format reports
  • Sensor History Reports option
EcoStruxure IT Support
Request Support
Back to Sensor History reports
  • Mark as Read
EcoStruxureIT
‎2019-11-20 06:14 AM
Create graph-format, table-format, or summary-format reports for the device groups or devices selected when you click the Custom option in the right-click menu, or the icon in the Device Groups, Alarm History, Active Alarms, or Device View. In addition, use this display to edit the report criteria for a or you have already created.
The devices and device groups, sensor types, and sensors listed by default in the "Report Criteria" display depend upon which view was used to access it:
  • Device Groups view: lists all sensors for all devices in the selected device group.
  • Device View or Map view: lists all sensors for a selected device or set of devices.
  • Active Alarms view: lists all sensors for a device associated with the selected alarm, or for the devices associated with a set of alarms.
  • Alarm History view: lists all sensors for the device associated with the selected alarm.
You can modify the report criteria before or after you create a report.
Note
When you click Generate Report, the report will not appear in the Saved Reports view until you use the Save icon to save the report.
Element Description
Choose Date Relative: select to use a drop-down menu option that identifies a period of time you want the report to cover.
Range: select to use to define the Start and End dates for the period of time you want the report to cover.
Choose Report Format Select to display the report in graph (the default), summary, or table format.
Choose Devices and Device Groups Select the devices or device groups you want to include in the report.
Choose Sensor Types Select the sensor types you want to include in the report.
Select Sensors
Search and Clear: use to search for a specific sensor, or to narrow the list to include only those sensors that include your typed text.
Configure Columns icon: identify the columns that appear in the display.
Sensors list: select the device sensors you want the report to include. When modifying an existing report, the list includes all sensors for the devices that were selected when the report was created or last edited, with the following information provided for each sensor:
  • Device: device label
  • Sensor: sensor name
  • Sensor Type: sensor type
  • Alarm State: current sensor status
  • Device Status: current device status
  • Hostname: device hostname or IP address
Select/Deselect All: use to select to include all sensors in the report, or to deselect the currently selected sensors.
