We Value Your Feedback!
Could you please spare a few minutes to share your thoughts on Cloud Connected vs On-Premise Services. Your feedback can help us shape the future of services.
Learn more about the survey or Click here to Launch the survey
Schneider Electric Services Innovation Team!
About the requirements for PMS Opera PMS and GRMS
Archives : Segment Specializations Forum
The Segment Specialization forum is your place to ask questions, find solutions, share knowledge, and submit ideas related to specific market segments, such as, Hotels, Healthcare, Retail, Real Estate, or Life Sciences.
  • Archives
  • Archives : Segment Specializations Forum
  • About the requirements for PMS Opera PMS and GRMS
Chris_Roberts
Lt. Commander Chris_Roberts Lt. Commander
5
JeanPaul_Genet
Ensign JeanPaul_Genet Ensign
4
MarinePETRY
Lieutenant JG MarinePETRY Lieutenant JG
3
Yves_Renaud
Lieutenant JG Yves_Renaud Lieutenant JG
2
Back to Archives : Segment Specializations Forum
sesa194123_brid
Lt. Commander sesa194123_brid Lt. Commander
Lt. Commander
Posted: ‎2015-08-10 02:28 AM . Last Modified: ‎2018-09-26 08:16 AM
1
545
    To use PMS and GRMS in a real project, you need to order the following items:
    •     Enterprise Server
    •     Report Server.
    •     Micros Opera PMS license.
    •     Micro Fidelio PMS Mongoose
    •     SBO GRM dashboard
    Enterprise server:
Hardware requirements
Processor ......................................................................................................................Minimum: 1.0 GHz
...............................................................................................................Recommended: 2.0 GHz or higher
Memory ..............................................................................................................................Minimum: 2 GB
...................................................................................................................Recommended: 4 GB or higher
Hard disk space ..............................................................................................................Minimum: 100 GB
The guidelines provided need to be scaled upwards as the system size grows in quantity of Automation
Servers or expected historical archiving. The testing of the largest 1.4.0 system was accomplished on a
machine with an 8 core @ 3.6 GHz processor, 32 GB of memory, and a hard drive of 3 TB.
Drive ..............DVD drive is required if your copy of StruxureWare Building Operation was delivered on disc.
Other devices ....................................................Microsoft mouse or compatible pointing device is required.
Software requirements
Operating systems ..........................................................................................Microsoft Windows 7 (32-bit)
.......................................................................................................................Microsoft Windows 7 (64-bit)
....................................................................................................................Microsoft Windows 8.1 (32-bit)
....................................................................................................................Microsoft Windows 8.1 (64-bit)
.................................................................................................Microsoft Windows Server 2008 R2 (64-bit)
.......................................................................................................Microsoft Windows Server 2012 (64-bit)
.................................................................................................Microsoft Windows Server 2012 R2 (64-bit)
The following Microsoft Windows 7 editions are supported: Professional, Enterprise, and Ultimate.
The following Microsoft Windows 8.1 editions are supported: Pro, Pro N, Enterprise, and Enterprise N.
The following Microsoft Windows Server 2008 R2 editions are supported: Standard, Web, Enterprise,
Datacenter, and Itanium.
The following Microsoft Windows Server 2012 and Microsoft Windows Server 2012 R2 editions are
supported: Datacenter, Standard, Essentials, and Foundation.
Required additional software ........................................................................Microsoft .NET Framework 4.5
Part number
SW-ES-BASE-0, StruxureWare Building Operation Enterprise Server license for a PC server, includes
Reports Server license
(No maintenance subscription included)
....................................................................................................................................SXWSWESXX00001
SW-EWS-1, EcoStruxure Web Services (run-time) option
Consume only for one Enterprise Server, no maintenance ..........................................SXWSWEWSX00001
    Report Server:
Processor .....................................................................................................Minimum: 2 Core @ 2.00 GHz
© 2015 Schneider Electric. All rights reserved.
Schneider Electric | Building Business www.schneider-electric.com/buildings
Trademarks and registered trademarks are the property of their respective owners.
03-15023-03-en February 2015[StruxureWare Building Operation]
3
.............................................................................................Recommended: 4 Core @ 3.00 GHz or higher
Memory ..............................................................................................................................Minimum: 4 GB
...................................................................................................................Recommended: 8 GB or higher
Hard Disk ..........................................................................................................................Minimum: 20 GB
Drive...............DVD drive is required if your copy of StruxureWare Building Operation was delivered on disc.
For more information on hardware requirements for installing SQL Server 2008 R2, see
http://msdn.microsoft.com/en-us/library/ms143506(v=sql.105).aspx/html.
For more information on hardware requirements for installing SQL Server 2012, see
http://msdn.microsoft.com/en-us/library/ms143506.aspx/html
Operating systems ....................................................................Microsoft Windows Server 2008 R2 (64-bit)
The following Microsoft Windows Server 2012 edition is supported: Standard.
The following Microsoft Windows Server 2012 R2 editions are supported: Datacenter and Standard.
SQL versions................................................................Microsoft SQL Server 2008 R2 (64-bit) SP2, English
................................................................................................Microsoft SQL Server 2012 (64 bit)*, English
The following Microsoft SQL Server 2008 R2 and Microsoft SQL Server 2012 editions are supported:
Standard and Express with Advanced Services
* Microsoft SQL Server 2012 SP1 is required if the operating system Windows Server 2012 R2 is used
For more information on software requirements for installing SQL Server 2008 R2, see
For more information on software requirements for installing SQL Server 2012, see
Web browsers supported for WebReports............................................Microsoft Internet Explorer 9 (32-bit)
......................................................................................................................Microsoft Internet Explorer 11
..............................................................................................................................................Mozilla Firefox
...........................................................................................................................................Google Chrome
Part number
No part number for Reports Server. Reports Server license is included with purchase of the StruxureWare
Building Operation Enterprise Server.
A license purchased from Oracle / Micros will be needed in order to get this interface enabled for a PMS. The associated cost will vary from customer to
customer, depending on their agreement with Oracle.
• Please contact your Oracle account manager or sales manager for more information.
• Schneider Electric will assist in the integration and ensure both systems are communicating per the specification.
  Please contact your Schneider Electric sales manager for a quote for the installation time
For more information about Fidelio and Micros Opera PMS, please consultant the following websit:
                  https://www.oracle.com/industries/hospitality/hotels-resorts/solutions/index
      Part No:  IFC_SXU 5007-134
      PMSMicro Opera Simulator setup
SBO GRM dashboard
      Hotel Guess Room Widget
  • Hotels
Tags (3)
  • grms
  • ibms
  • pms
sesa355633_brid
Lieutenant sesa355633_brid Lieutenant
Lieutenant
Posted: ‎2017-12-14 11:31 AM
Oracle Site link isn't working, Can you update it ?
This is a heading
