Wiser by SE App - How to Add a Wiser Hub (Ethernet Mode)
  • Wiser by SE App - How to Add a Wiser Hub (Ethernet Mode)
David_SE
Captain David_SE Captain
140
Alfred_SE
24
Maude.wiser.
22
Alfred_SE
Posted: ‎2021-12-22 08:42 AM . Last Modified: ‎2022-01-18 12:39 AM
1
3223
The Wiser Hub enables you to easily manage your home environment. It connects Wiser devices and enables communication between multiple devices and a smartphone via the Wiser app. The hub also enables voice control and allows you to control your home from a remote location.
Selecting a location for the hub:
The hub is the central controller of the system and must be within range of all devices in order for the system to work properly.
The ideal location for the hub is determined by the following:
• Layout of the building where the system is installed
• Location of other devices that will be used in the system
Referring to the next diagram, it is most important to locate the hub (A) as central as possible to the area occupied by all mains-powered devices (B), such as switches and dimmers. Proximity to battery-powered devices (C) should also be considered in context with the tip mentioned after the diagram.
TIP: The battery-powered motion sensor in the garage (D) is a long way from the hub. However, the sensor can connect to the hub via the mains-powered device being used as the garage light switch (E). This is because mainspowered devices also act as system network extenders. Consider this when deciding where to locate the hub.
Features:
  • Wiser central communication interface
  • Connects devices and enables communication via the Wiser by SE app
  • Enables voice control and control over your home from a remote location
  • Can be placed on a table using the optional table stand or mounted on the wall
  • Enables scene control (moments) and automation functions
In this video, we will show you how add a Wiser hub using the Wiser by SE app.
Alfred Francis
  • Apps
  • Gateways
  • Wiser Hub
Schneider_Community_Team
Lieutenant Schneider_Community_Team
Lieutenant
Posted: ‎2023-10-04 05:52 AM
Useful video, thank you for sharing
Lieutenant
