Wiser Smart Plug keeps dropping off the Heat Hub and won't reconnect
  • Wiser Smart Plug keeps dropping off the Heat Hub and won't reconnect
David_SE
Captain David_SE Captain
139
Alfred_SE
24
Maude.wiser.
22
BrianT58
Lieutenant BrianT58
18
RobinTG
Ensign RobinTG
Ensign
Posted: ‎2024-04-05 08:07 AM
2734
I have an installation which has 13 Wiser Radiator Thermostats, 2 Room Thermostats, and 3 Smart Plugs (used as range extenders and to switch lamps on an off) plus a Heat Hub.
Every 2 or 3 months, one particular Smart Plug appears to crash and stops functioning and can no longer be seen on the system. Removing and reinserting the Smart Plug into the socket outlet doesn't get it to reconnect to the Heat Hub. Repeating the 'Join Smart Plug to the Heat Hub' process (press and hold ON/OFF button for 2 seconds) fails to reconnect the Smart Plug to the Heat Hub. I have to remove the Smart Plug from the Heat Hub using the app and do a factory reset of the Smart Plug and redo the joining process from scratch. I've now done this several times which is becoming a real pain!
The issue seems to occur only with one out of the three Smart Plugs. Is it possible that this particular unit has some sort of recurring fault?
What long term solution options do I have (short of replacing the Wiser system with one from another manufacturer)?
RobinTG
Ensign RobinTG
Ensign
Posted: ‎2024-11-12 03:15 AM
In response to Maude.wiser.
2098
Hi Maude, I've done as you suggested and sent an email. Let's see what they have to say!
David_SE
Captain
Posted: ‎2025-04-14 10:20 PM
In response to DrJohnM
Hi @DrJohnM ,
Since the last comments from Robin, we delivered some system releases and some corrections & improvements were provided. If you have a similar issue, i propose you to create a new post and to provide your system details & behaviour so we can share with you a personalized answer.
BR
David
RobinTG
Ensign RobinTG
Ensign
Posted: ‎2025-04-15 08:35 AM
Hi everyone
Just to say the problem does appear to have gone away so fingers crossed that the tech guys at Schneider have fixed it!
Many thanks Robin
Replies 8
andrew_
andrew_
Cadet
Posted: ‎2024-08-31 01:44 PM
2550
I have this problem, but it's happened on more than one plug. One of them just decides it's had enough and will disconnect. Doing a reset and re-add is also painfully slow and unreliable. They're pretty flaky. Did you ever find a solution?
volker81k
Crewman volker81k
Crewman
Posted: ‎2024-09-04 12:19 AM
Hi all,
I have a similar issue with one thermostat. It shows offline the odd time, but after re-seating the batteries the device shows normal operation again.
But it is only 1 of 9 showing this behaviour.
Maude.wiser.
Lieutenant
Posted: ‎2024-11-11 08:27 AM
2157
How are you doing ? I was wondering if you could contact our technical support as it seems to be a bug: 0333 6000 622 or support@schneider-electric.zendesk.com
Thanks in advance,
RobinTG
Ensign RobinTG
Ensign
Posted: ‎2024-11-12 03:14 AM
In response to andrew_
Hi Andrew, not yet! See message from Wiser person at the bottom of this thread!
RobinTG
Ensign RobinTG
Ensign
2099
DrJohnM
Ensign DrJohnM
Ensign
Posted: ‎2025-04-10 11:17 PM
In response to RobinTG
1338
Did you get an actual solution to this issue?
 Regards
David_SE
Captain
Hi @DrJohnM ,
BR
David
RobinTG
Ensign RobinTG
Ensign
Hi everyone
Many thanks Robin
