Wiser - Pairing the Unica connected Universal push button dimmer
  • Wiser - Pairing the Unica connected Universal push button dimmer
David_SE
Captain David_SE Captain
149
Alfred_SE
24
Maude.wiser.
22
Esperanto
Lieutenant JG Esperanto
Lieutenant JG
Posted: ‎2022-01-20 04:41 AM
2
1549
How can I pair my Connected Universal push button dimmer?
  • Apps
Alfred_SE
Posted: ‎2022-01-20 07:24 AM
1543
Hello, thank you for your question
. You can pair the device manually:
Follow the steps to pair the device manually:
  1. On Home page, tap + icon.
  2. Tap the dimmer icon and select the Wiser Hub.
  3. Select any one of the options to add device (A):
  • Add Device with Install Code
  • Add Device without Install Code
6. To add the device with Install Code, tap Add Device with Install Code button to open the slide-up menu. Select any one of the options (B):
  • Scan Install Code - You can scan the device for the Install Code
  • Enter Install Code Manually - You can manually enter the install code from the device
After adding the device with Install Code, proceed to Step 6.
TIP: It is recommended to add the device with Install Code for security purpose.
5. To add the device without Install Code, tap Add Device without Install Code.
6. Short press upper part of the push button 3 times (< 0,5 s) on the device.
The LED blinks amber
7. In the app, select Confirm LED is blinking amber and tap Start configuration (C)
The app displays the progress of connecting the device
8. Wait for a few seconds until the device is connected and the app shows that the device is added successfully.
The stable green LED on the Dimmer shows that it is successfully connected to the Gateway
9.
After the device is added in the app, tap Done.
Alfred Francis
Alfred_SE
Posted: ‎2022-01-20 07:27 AM
In response to Alfred_SE
You can also pair the device with auto scan:
Pairing the device with auto scan automatically discovers the device when the corresponding device is powered on.
Follow the steps to pair the device:
  1. On the Home page, tap + icon.
  2. Tap Auto scan tab and tap Confirm.
  3. If you have multiple hubs, do Step 4 or proceed to Step 5.
  4. Tap Select hub and select the Wiser hub from the slide-up menu.
  5. Short press upper part of the push button 3 times (< 0,5 s).
NOTE:
  • The LED blinks amber.
  • Wait for a few seconds until the device search is complete.
    6.Tap Push Button Dimmer and tap Next (A).
    7. Once the device is added successfully, tap Done.
Alfred Francis
Alfred_SE
1544
9.
Alfred Francis
Alfred_SE
NOTE:
Alfred Francis
