Error using LSS100100
  • Error using LSS100100
David_SE
Admiral David_SE Admiral
151
Alfred_SE
24
Maude.wiser.
22
Wiser for KNX : logic controller
DSilva2002
DSilva2002
Cadet
Posted: ‎2024-11-27 04:25 AM
1174
Hello
I'm having some issues with wiser4Knx. I'm having problems with connection by ip adress, the Led 1 starts blinking and the led 2 is off. I've read some topics that says that this is caused by a problem with the sd card. At the same time, this error shows me when i acess other wiser's and i'm questioning if this can cause problems in the sd card. How can i reset and delete this error and what this error means? Also, i looked at the debug of ETS6 and doesn't show a lot of traffic that could cause this problemdownload.png
  • About Wiser
David_SE
Admiral
Posted: ‎2025-04-08 02:35 AM
hi @DSilva2002 ,
Thanks for your post and sorry for the late reply.
As you are on Wiser KNX issue, we have also a dedicated KNX forum for KNX questions.
Please find here the link. I closed that post and i hope you will open one in the "right" community.
Thanks.
BR
David
David_SE
Admiral
hi @DSilva2002 ,
Thanks.
BR
David
