Electrical heat swich without room thermostat
  • Electrical heat swich without room thermostat
David_SE
Captain David_SE Captain
144
Alfred_SE
24
Maude.wiser.
22
Kaboo
Crewman Kaboo
Crewman
Posted: ‎2024-09-02 04:16 AM
695
Hi everyone,
I am looking to install electrical heat switch with towel rail in my WC. In the wider home setup, I have HUBr and one Room Thermostat which sits inside my living room, then have 6 Wiser radiator thermostats in the various rooms and hallway.
From my reading the manual and instructions, Electrical Heat Switch needs to be paired with a Room Thermostat? Is that correct? If so, will it occupy the only room thermostat that I have and the thermostat will need to sit inside the WC? That will be an overkill to put a pricey thermostat in a tiny WC.
Cheers
  • About Wiser
  • Temperature Control
  • Electrical Heat Switch
  • wiser
David_SE
Captain
Posted: ‎2025-04-08 01:33 AM
Hi @Kaboo ,
Thanks for your post and sorry for the late reply. I confirm that you need a room thermostat to control one electricial heat switch/radiator. For your WC, it is possible to put a smart plug instead of the couple "Electrical heat switch+Room thermostat".
BR
David
David_SE
Captain
Hi @Kaboo ,
BR
David
