Posted: 2022-05-17 02:25 PM
There’s a feature missing from the Wiser App: Away Mode is great, and has saved me some energy, but you have to remember to turn it off by hand. It would be really nice to be able to set a date and time at which away mode would turn off automatically, thus making my house nice and warm when I get home without needing to remember to do something manually. .
Jon
Posted: 2022-05-20 02:31 AM
Hello!
Thank you for your feedback, we consider all user feedback very carefully in our ongoing app development. We have noted your suggestions as feature enhancement requests for future consideration.
However, I can suggest you an alternative by assigning a schedule to your heating system that will make your house nice and warm when you get home without even doing something manually.
Posted: 2022-10-06 04:16 AM
The time applied to Away mode would be useful for holidays (returning 2 weeks from today) and ad-hoc events - e.g. going out to cinema and not back until 10pm.
Posted: 2022-10-25 10:11 PM
I agree with this idea. The absence mode is important. On the occasion of a weekend or a day of unexpected absence, it would be necessary to be able to indicate the date and time to allow Wiser to resume his program.
This evolution made it possible to enter a heated house without having to change the programming each time. Many other solutions allow this finer management of the return.
Thank you.
Posted: 2022-10-26 01:52 AM
@Alfred_SE thanks for your response, but it's not a solution and shouldn't be marked as such.
Yes, I can (and do) create a special *heating* schedule when I'm away, but that's a weekly cycle and so if I'm away for more than a week it doesn't solve the problem. And it's non-trivial to copy and edit a schedule just because I'm away - that's too much time. But it's not possible to create more than one hot water schedule, so your suggestion doesn't work at all for hot water.
Perhaps I wasn't clear enough: I use away mode for when I'm away for several days - and setting an end date/time for away mode would mean that i can simply tell the system that I'm away for now, am back on such-and-such a day, and to turn the heating and hot water down/off for the duration.
MiGenie - your previous product - did this, I don't know why Wiser still doesn't.
Jon
Posted: 2022-11-11 09:46 AM
Additionally, setting an end time to the away mode could also allow Comfort mode to take effect, so that the house was warmed up by the point away mode is scheduled to end. This would avoid turning away mode off too early and wasting energy, or too late (or forgetting) and coming home to a cold house.
James
Posted: 2022-11-21 04:11 AM
A definite +1 on this from me too please.
Every digital thermostat I've ever owned had the facility to specify an away period and while I'm very pleased with the Wiser system I miss this feature.
I've coded my own using a scheduler and an IFTT callback but I'd be happier if it was inside the control box to avoid a connectivity issues resulting in returning to a cold house.
Posted: 2022-12-20 04:00 PM
Hi
I've just asked for this too. But I see the request is marked with a solution, except that I don't see how the solution of setting a schedule would work. Is there a schedule setting that overrides 'Away Mode'?
Posted: 2023-01-22 12:51 AM . Last Modified: 2023-01-22 12:53 AM
Yes, definitely needed - the ability to say the system should switch to a mode at a certain date and time, and that it should switch to "Normal" mode (which would turn "Away" mode off) at another date & time.
Presently there is no button for "Normal" mode.
Presently returning from a holiday and turning off away mode relies on wiser maintaining it's internet connection ... we do know it drops out and doesn't reliably auto reconnect. To negate this on the home system, i have the boiler and wiser control running through a smart plug that i can use to power the system off for a few minutes or even schedule a 5 minute shutdown each night to power cycle the controller.
Posted: 2023-02-02 12:20 AM
A +1 from me too. I often forget to switch it off until am back inside and kids complain 😛
Posted: 2023-03-21 02:15 PM
This feature is needed and the solution suggested by Alfred is not a real solution.
Posted: 2023-03-21 02:20 PM
So can we take this feature forward please?
Posted: 2024-01-18 01:04 AM
woould be great to see this feature in the future. I do not think this thread should be marked as solved.
The solution is not an option for extended periods of absence. As teh other posters have noted too.
I think there is a real benefit in adding this feature. Many thanks!
Posted: 2024-01-27 07:06 AM
can I ask why this is marked as solved as there isn't a timed away mode? great that you are looking into it but until that solution is available surely it shouldn't be marked as solved.
Posted: 2024-03-27 09:01 AM
I think what makes it worse is that MiGenie had this feature so I “lost it” when forced to “upgrade” to Wiser
Posted: 2024-03-29 02:05 AM
It’s approaching two years since you “noted” this feature request. When is it going to be
possible to set an end time for away mode? (Like you could in MiGenie)
Posted: 2025-03-28 07:38 AM
This is still not a solution.
If I'm away for a couple of weeks, I want the heating to stay in away mode until I come back. I can't create a two-week schedule that holds the temperature at one level while away, and makes the house toasty when I get home.
And none of this works for hot water - it's only possible to create a single hot water schedule, so I wouldn't be able to use this workaround.
The only solution I have right now is to use a third party app that pokes and prods wiser to do the right thing. I wouldn't need to do this if wiser let me set an end date/time for away mode.
Posted: 2025-04-03 02:46 AM
Still waiting on an appropriate response to this thread as setting a schedule is not the answer.
Posted: 2025-04-06 01:59 PM
also would be good if you can set up a one time change for hot water if you need to get up earlier than usual. i.e timed boost mode so you dont have to manually edit the schedule then put it back again!
Posted: 2025-04-08 02:26 AM
Hi All,
Thanks for your post and your improvement request. I will share that with our team and it can be taken into account for future releases.
BR
David
Posted: 2025-04-08 03:08 AM
I came back here after a couple of notifications saying it was solved. Sadly not. Quite embarrassing this basic heating control feature is still not included years later. I've had to tweak my IFTTT solution since they started charging but still works ok via a custom api. Not suitable very most users though. I also didn't realise it wasn't turning off the hot water ('cause I'm away but still want water heating?) but just seen an option seems to have been added to the app to do this.
While I'm here I'll also see if there's a thread with people complaining about this useless new Home screen that just means I have to click another button to get to my heating controls...
Posted: 2025-04-14 10:28 PM
Hi @wer11 ,
Thanks for your post. Sorry but we are not able to share with you a date to deliver the away mode features you requested.
concerning the new Home screen, a new app version will be delivered in the coming days and it will propose you to set which "page" you want to open the app.
BR
David
Posted: 2025-04-15 01:12 PM
Does the feature even exist in the program of work? I know that it would be useful and appreciated. What features have a higher priority?
Posted: 2025-04-18 12:49 AM
Posted: 2025-10-17 12:43 PM
Come on Schneider, this is is an obvious missing feature that needs to be added.
Posted: 2025-10-17 12:54 PM
For the benefit of other users, it’s possible to write a Shortcut on iPhone that you can run from Siri or from a widget on your lock screen. When you run the shortcut it:
Posted: 2026-10-03 12:03 AM
This feature must be embedded into the gateway. Because I already have the case where I have a connectivity issue with my box then I was not able to restore the heating before I come back to home.
Posted: 2026-10-06 01:55 AM
Over 4 years ago this was raised as a topic and David_SE marked it as solved and told us we were "looking into it"
Clearly bringing in a feature that users want and should have been there from the start isn't of interest to Schneider.
Posted: 2026-10-06 10:15 PM
Hey @David_SE , will SE be adding this glaringly missing and much needed feature for this coming winter?!
Posted: 2026-10-07 11:12 PM
But it does depend upon you having internet access at the time that it runs. As I said some time ago, this could/should be a basic feature of the system.
Posted: 2026-10-08 01:56 AM
Within the controller device this should be a trivial feature to add. It's already spending all its time running a day/time based schedule to turn things on and off. This is just adding the facility to turn something off based on an absolute date/time. I suspect they just can't be bothered adding the UX to the app to set it in the first place.
My own custom API solution is still working 4 years on but I generally don't recommend this platform to other people due to this glaringly obvious missing feature. I believe one of the most important ways to manage your energy costs is to be able to confidently avoid heating an empty house. By confidently I mean not feeling at risk of coming home to a stone cold house.
Posted: 2026-10-14 12:42 AM
Posted: 2026-10-14 11:04 PM
Thank you for your honesty. What functional are you adding?
