Posted: 2021-09-21 02:26 PM
Hello Experts!
I know this isn't a standard application, I am pretty sure this isn't recommended but my costumer need this.
I have a Sepam S40 protection Relay. This relay is control 3 CBs in one time. I disabled the circuit breaker control functions to use freely the I11 and I12.
The protection is controlled by Power Scada Operation with ModbusTCP. Now I want to operate the outputs by SCADA commands. From the Hungarian SE Support I got the information I can do this with the TC bits which is assigned to the V bits by Logical Equations.
My question is: How can I do this because I can't find the TC bits in the logical equations. Or if it’s impossible, where can I find documents to prove that it’s impossible?
Thanks you for your answers!
Hi @Anonymous user,
Yes, you are right, unfortunately in the S40 series, we do not have Generic commands like the 80 series TC. They should be made a mixup with 80 series.
The unique way you can do it is by using a digital input to command the DJ.
It is a limitation of this model.
Best Regards
Here is where you can prove it to your customer, all TC in 40 series are pre-defined functions and cannot be used as generic controls (page 172 of the attached manual)
Hi @Anonymous user,
Best Regards
Posted: 2021-09-22 11:05 AM
Thank you very much to your answer!
I forwarded this information to my customer.
Posted: 2021-09-24 01:37 AM
Just one more question @AndreMelo , with S80 protection is possible to do this application. If we change the S40 to S80 I will can access the TC bits in logical equation?
Hi @Anonymous user ,
Yes, you can, with 80 series you can use the TC in both Ladder logic and Logic equation, just pay attention in the manual cause some TC has a pre-assigned function.
However, for this kind of application, I would prefer to use a P3 since it has pre-defined objects. But anyway, the answer is YES.
